vcScope
A container for statements.
Module: vcExecutor2
Referenced by: vcIfStatement.ElseScope, vcIfStatement.ThenScope, vcMultiScopeContainer.Scopes, vcMultiScopeContainer.copyScope(), ... (see more)
vcMultiScopeContainer.createScope()
vcRoutine.Scope
vcSingleScopeContainer.Scope
vcStatement.ParentScope
NameStringRWGets or sets the name for the scope.
ParentvcObjectRvcExecutor2.vcRoutine | vcExecutor2.vcStatement: Gets the parent of the scope.
RuntimeError: When internal error occurs because of orphan scope."
RoutinevcRoutineRGets the owner routine.
StatementsvcList[vcStatement]Rlist[vcExecutor2.vcStatement]: Gets the contained statements.
clearStatementsNoneNoneDeletes every statement in the scope.
None
None
copyStatementvcStatementvcStatement statement,
Integer index
Clones the statement within or into this scope.
statement (vcExecutor2.vcStatement): A statement to clone.
index (int): Index to insert the statement to. Must be zero or positive.
If index is greater than the number of contained statements, the cloned statement is added to the end.
vcExecutor2.vcStatement: The copied instance.
RuntimeError: When copying fails due to incompatible statement.
createStatementvcStatementString type,
Optional Keyword[index = Integer]
Creates and adds a new statement into the scope.
type (str): Type name of the statement.
Optional: index (int): Index to add the statement to. Must be zero or positive.
If index not given or is greater than the number of contained statements, the statement is added to the end.
vcExecutor2.vcStatement: The new statement.
ValueError: When the type name is invalid or creation fails.
deleteNoneNone"
Deletes the scope. Only certain scopes can be deleted.
None
None
TypeError: When scope cannot be deleted.
moveStatementNonevcStatement statement,
Integer index
Relocates the statement within or into this scope.
statement (vcExecutor2.vcStatement): A statement to move
index (int): Index to move the statement to. Must be zero or positive.
If index is greater than the number of contained statements, the statement is moved to the end.
None
RuntimeError: When move fails due to incompatible statement.
NameParametersDescription
OnStatementAddedvcStatement statementInvoked when a statement is added to the scope.
statement (vcExecutor2.vcStatement): The newly added statement.
OnStatementRemovingvcStatement statementInvoked when a statement is about to be removed from the scope.
statement (vcExecutor2.vcStatement): The statement about to be removed.
